вывод команды dmesg покажите последние строк 20-30
лучше спрятать под спойлер
…доступ в прошивку по SSH login “root” password “purefox”
dmesg | tail -n 30
[ 1.539828] phy phy-ff3e0000.usb2-phy.0: illegal mode
[ 1.539840] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.539870] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.540070] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 1.540088] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008022010010
[ 1.540137] xhci-hcd xhci-hcd.0.auto: irq 48, io mem 0xffb00000
[ 1.540914] hub 1-0:1.0: USB hub found
[ 1.540960] hub 1-0:1.0: 1 port detected
[ 1.684653] rk_gmac-dwmac ffa80000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 1.795748] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
[ 1.795920] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 1.796298] dwmac4: Master AXI performs any burst length
[ 1.796326] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
[ 1.796345] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
[ 1.796627] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
[ 1.947247] usb 1-1: 1:2 : unsupported format bits 0x100000000
[ 1.950755] usb 1-1: Warning! Unlikely big volume range (=512), cval->res is probably wrong.
[ 1.950773] usb 1-1: [10] FU [PCM Playback Volume] ch = 2, val = -16384/0/32
[ 3.848370] rk_gmac-dwmac ffa80000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 3.848420] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4.881768] rockchip-i2s-tdm ffae0000.i2s: MCLK multiplier set to 1024x
[ 4.882052] rockchip-i2s-tdm ffae0000.i2s: MCLK rate changed to 49152000 Hz (multiplier 1024x, forced despite mclk_calibrate)
[ 4.882298] rockchip-i2s-tdm ffae0000.i2s: Postmute delay set to 100 ms
[ 4.901788] rockchip-i2s-tdm ffae0000.i2s: PCM Channel Swap (LRCK inversion) DISABLED
[ 4.919537] rockchip-i2s-tdm ffae0000.i2s: DSD Physical Channel Swap enabled
[ 4.919560] rockchip-i2s-tdm ffae0000.i2s: DSD Physical Channel Swap setting saved (will apply in DSD mode)
[ 4.962687] random: crng init done
[ 12.620409] rockchip-i2s-tdm ffae0000.i2s: User unmute: no stream, keeping mute ON
[ 12.854618] rockchip-i2s-tdm ffae0000.i2s: Runtime resume: enabling mclk_tx and mclk_rx
[ 12.854652] rockchip-i2s-tdm ffae0000.i2s: Runtime resume: mclk_tx and mclk_rx enabled successfully
в dmesg чисто.
Можете запустить плеер в консоли, чтоб видеть полный лог
killall raat_app && /opt/RoonReady/raat_app /etc/raat.conf
Последние строчки показывают, что у вас прошивка стояла в режиме I2S, а не в USB
Вот ещё раз проверил стоит на USB ну как вы сказали показывает I2s
Перезапустите плеер как показывал.
Там мы точно увидим какое аудио устройство он цепляет.
Кстати! А в веб интерфейс кнопка Roon сама собой не отжимается? Не становится неактивной?
С кнопкой все нормально всегда активна
Лог плеера тоже показывает стабильное соединение с U30.
Пока не вижу никаких ошибок.
Давайте завтра продолжим. Или дадите доступ по анидеску. Быстрее можно будет разобраться.
Но это завтра. Мне вставать рано…
спасибо большое. Да конечно до завтра.
Павел здравствуйте, подскажите нет ли возможности в стандартную прошивку добавить яндекс музыку? Чтобы обновится по воздуху. Думаю многим будет интересно.
Можно через LMS использовать Яндекс.
Это дополнительные костыли, я не знаю как использовать LMS и яндекс. Для музыки использую руун. А тут прямо все в прошивке встроено. Очень удобно.
На дастерео к руну яндекс прикрутил один умелец
Вроде как логично прикручивать к серверной части. А то идея эндпоинт теряет весь смысл. Хотя говорить о качестве контента Яндекс говорить не приходится… ИМХО
Кто же его качественно слушал то, если и реализации то не было толковой. Но недавно качество обнулили и можно не торопиться.
@ppy Павел, добрый вечер! Есть просьба по Qobuz Connect в PureFox.
Делаю на базе PureFox своё устройство. В нём лиса подаёт I2S в DSP-кроссовер, а рядом стоит свой контроллер на STM32, связанный с лисой по UART. На нём передняя панель с кнопками, ИК-пульт и экран, где видно трек, формат, позицию и обложку. Хочется управлять воспроизведением с самого устройства, без телефона в руках: поставить на паузу, переключить трек с дивана пультом.
Посмотрел, что есть в libqobuz_connect.so. В SDK для этого уже есть всё нужное: qbz_connect_pause_playback, qbz_connect_resume_playback, qbz_connect_next_track, qbz_connect_previous_track, qbz_connect_seek_time, а также qbz_connect_get_playback_state и qbz_connect_get_stream_metadata. Но обёртка qobuz-connect их сейчас не вызывает. Её локальный HTTP отвечает только на get-connect-info, get-display-info и connect-to-qconnect.
Можно ли открыть эти функции наружу? Подойдёт любой удобный вам способ: несколько команд в существующем локальном HTTP-сервере, unix-сокет или FIFO. Например:
команды: play, pause, next, prev, seek <мс>;
состояние: статус воспроизведения, название, исполнитель, альбом, ссылка на обложку, позиция и длительность, частота и разрядность потока.
Сейчас метаданные я вытаскиваю из текстового лога плеера, а позицию считаю по кадрам драйвера. Это работает, но хрупко: любое изменение формата лога всё сломает. С командами и состоянием от самого плеера всё стало бы надёжно, и кнопки заработали бы официальным путём, через SDK.
Неофициальные клиенты Qobuz городить не хочется.
Любопытно, от чего зависит громкость щелчка при подачи dsd on на плату i2s to hdmi и далее. Макс стал странно себя вести, купил новый, просто заменил, те же провода, тот же припой, и вот вместо ещё слышного щелчка теперь очень громкий
Вам нужен только указатель на сессию, его можно перехватить. Плеер передаёт его первым параметром в qbz_connect_connect а эту функцию он точно вызывает.
